non-corvette question - NCRS Discussion Boards
  • mike mccagh
    anybody out there have a 57 chevy pass car(Nomad not sedan deliver nor wagon won't work). i replaced the trunk floor pan in the 57 pass car fuelie i've been fooling with for years. threw the original trunk pan away. repo lacks hole for fuel sending unit wire. if someone has a sedan or hardtop, could you take some measurements of the hole for the fuel sending unit wire. thanks guys, mike
  • harley parmenter
    Re: non-corvette question
    Mike, I checked a 56 4 door hardtop with original trunk floor. The half inch hole was 4and 3/4 inches behind the centerline of the rear shock studs and in the center of the left reinforceing rib. Hope that will help and be the same as 57 Harley Parmenter
