BB Exhaust Manifold Bolts, Locks and Spacers? - NCRS Discussion Boards
  • Larry Kelly
    I am ready to install the exhaust manifolds on my 68 427. When I took it apart there were no lock washers on the bolts. In the past I have taken other exhaust manifolds on and off of other cars and my recollection is that none had any kind of lock washers. I guess this makes sense, the heat must eventually degrade the retaining ability of the lock washer. To further complicate this, I have seen SB french locks but can't find them for BB. What should I use, locks or no locks?
  • ken edmunds
    Re: BB Exhaust Manifold Bolts, Locks and Spacers?
    No lock washers. The Paragon part number for the french locks is 1161K.
    • Larry Kelly
      Ken, The Paragon #1161K french locks are listed as 66-80 w/327-350. My engine is a 427. Do these fit a BB also? Thanks, Larry
        • 43221
        Larry-----
        The Paragon part number for the big block french locks is 1027K. Most of the other vendors carry these, too.
        However, I do not think that these french locks were originally used for later 1967-74 big block applications. For these applications I believe that GM changed to a special flanged head, locking-style bolt for the end runner bolts. No washers were used with these bolts. These are GM #3909821 and they remain available from GM.
        The remaining bolts were non-locking bolts and the same as used for previous big block applications at all positions. No washers or spacers were used with these bolts.
        • Terry F.
          • September 30, 1992
          • 2061
          Very confident, no french locks on exhaust manifolds for 68. Terry
