C-3 Power antenna motor - NCRS Discussion Boards
  • Doug F.
    • June 30, 2005
    • 136
    I have 78'vette that the power antenna doesnt go up nor down but i can hear the motor of the antenna cycle when i turn on the radio knob. What does it take to get it to work if the motor is working?,, thanks,, a do it yourselfer here,, doug
  • Robert S.
    • July 31, 2004
    • 377
    Re: C-3 Power antenna motor
    Doug, If you heard the motor running then you probably have a broken nylon cable inside the case. This is what happen to mine. The nylon cable broke just after the point were it attached to the spool that the motor drives. I beleive I got a replacement from CC. It wasn't perfect but I got it to work.
    Good luck,
    Bob
    Bob
