C3 Flywheel? - NCRS Discussion Boards
C3 Flywheel?
  • Wes G.
    • December 1, 1999
    • 99
    C3 Flywheel?
    Can anyone identify the casting number 3973468 N A21 0 as found on my flywheel? Is the A21 0 a date code for Jan 21/70? Is there such a number, or have I read the casting number wrong and should be 3973458 N as discussed in earlier posts found in the archives.
    Wes #33239
    • 43221
    Re: C3 Flywheel?
    Wes-----
    I think that you're incorrectly reading the 6th digit as a "6" when it's actually a "5". Nonetheless, whatever the number, I'm sure we're talking about the same flywheel. It's a standard weight, 14", 168 tooth flywheel designed for use with a 14" clutch. The date code is as you surmise. That makes this flywheel one of the first produced as this casting was released in late 1969.
      • 43221
      Correction
      Designed for use with an 11" clutch; NOT a 14" clutch
      • Wes G.
        • December 1, 1999
        • 99
        You're right Joe, I was reading a '6' for a '5'. T *NM*
