61-62 Tire Iron - NCRS Discussion Boards
61-62 Tire Iron
  • Christopher R.
    • March 31, 1975
    • 1599
    61-62 Tire Iron
    I've got a tire iron that is correct in every way for 61-62 except for the bend or hook on the end. Can the end be bent without heating it? Do you think that if I hammered it cold over an anvil that it would bend in such a way that it would look like the manufacturer did it? How did the manufacturer do it?
  • mike mccagh
    Re: 61-62 Tire Iron
    i'd heat it then bend it over the anvil. try to retain the "sheared" appearance of the three sides of the end you're bending. good luck, mike
