Engine Vendor
Tags: None
- Top
Re: Engine Vendor
1000 bucks rarely gets one a rebuilt SBC , by a professional machine shop using top quality replacement parts. if cast # and cast date and pad data unimportant to you, why not get a crate engine from GM. all new parts, good guarantee from a company that should(?) be around for awhile. last time i got one they were about 1300 bucks. mike- Top
Re: Engine Vendor
Here's my budget long block for my truck project. I shopped for parts and cutu it tight. Also assembled it myself. I don't know how it could be done much cheaper and the shop still turn any profit. I'd be curious as to what parts they are using.
355 Chevy Short Block Cost Summary
Parts:
H&W Auto Parts Machine Shop
Hicksville OH 43526
419-542-8513
and
H&W Auto Parts
Edgerton OH
419-298-2341
Pistons, SilvOLite H1279030 $86.00
Piston rings, Hasting Moly 28.95
Cam bearings, Clevite77 22.95
Expansion plugs 6.95
Engine paint, 3 cans cast grey 12.27
Offset lip rear main seal JV-1627 10.61
Timing cover gasket set with balancer sleeve JV-919 22.92
Sub total $160.65
The Eastwood Company
www.eastwoodco.com
Glyptal paint, 1 qt brush on. 46001ZP $24.95
Summit Racing Equipment
www.SummitRacing.com
Assembly lube $ 1.50
Rod bearings,Clevite 77 CLE-CB663P 20.00
Main bearing set, Clevite 77 CLE-MS909P 20.95
High Volumn oil pump, Melling MEL-M55HV 21.95
Hardened oil pump drive w/steel coupler, Melling MEL-IS55E 6.95
Oil pan gasket, Fel-Pro one piece, FEL-OS34509T 34.39
Sub total $105.74
Maxton Motors, Inc.
114 W. Main St.
Butler IN 46721
1-888-462-9866
Chevy, Pontiac, Olds, Buick, Chevy Truck
GM Performance camshaft and lifter kit, Mfg by Crane, 1235918 $161.87
Balancer bolt 3815933 2.75
Balancer washer 14001829 2.97
Sub total $167.59
Total freight/handling on all parts $34.91
Total sales tax on all parts $32.57
Parts total $526.41
Labor
Hicksville OH 43526
419-542-8513
Clean block $ 41.50
Bore block and fit pistons 135.00
Press piston pins 52.00
Install cam bearings 32.25
Install expansion and block plugs 18.60
Sales tax on labor (yes, this is Ohio) 16.77
Total labor $296.12
Short block total $822.53
350 Chevy Heads cast # 3998993 Cost Summary
Parts:
H&W Auto Parts
Head Gasket Set .020 compressed thickness steel shim Victor HS-1178-BJ $29.24
Valve Seals (16) 11.04
Exhaust guides (8) 10.00
Intake valves (8) 29.76
Exhaust valves (8) 27.20
Performance valve springs 160-1144HP 25.60
Valve locks 8.64
Sub Total $141.48
Freight 6.95
Sales tax 9.90
Head Parts Total $158.33
Labor:
Clean heads and Magnaflux
R&r valve guides
Mill surface .020
3 angle valve job and assembly $251.45
Sales tax 17.60
Head Labor Total $269.05
Total To Rebuild Heads $427.38
Total Cost To Rebuild Engine $1249.91
(Short block total plus head total)- Top
