69 L46 Harmonic Balancer Codes - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    The harmonic balancer has a casting number 3942538, which I believe is correct for a 69 L46 with AC. There are some other codes that I would like to find out what they translate to.
    On the front side the following codes stamped in approx 3/16" high font is
    7712 and I8F. The I could be a J.
    On the back side is the casting number 3942538 (all info is a raised cast) and the letters GB in an oval on one of spokes. In addition, cast in is the letter B on one of the other spokes and the letter K on the remaining spoke.
    George
    • 43240
    Re: 69 L46 Harmonic Balancer Codes
    George-----
    The "7712" is a derivative of the original part number for the balancer, GM #3947712. These derivatives are sometimes found on original or SERVICE balancers.
    3942538 is the casting number for the hub section of the balancer. It may have been used for other balancers, too, so it does not necessarily ID the balancer's finished part number. The "I or J 8F" is likely a date code, but I don't know how to decode it.
    The "GB" is likely a reference to the manufacturing source of the balancer hub casting or the balancer manufacturer.
    I don't know what the "K" and "B" refer to. They may be reference marks or some pattern identifier.
    • George D.
      • August 31, 2000
      • 225
      Re: Thanks Joe 69 L46 Harmonic Balancer Codes
      Joe,
      Thanks for responding. Your vast knowledge is greatly appreciated.
      George
