Are the rear axle codes located near the GM casting no.or on the other side. From what I understand it's located on the right side,however the carrie unit is quite rusted and pitted making location impossible. I'm trying to determine if my car was originally an automatic. The prefix on the block is stamped with SD which indicates powerglide but it is equipped with a 4 speed.
Thanks alot.
Deb
Thanks alot.
Deb
