power steering pulley - NCRS Discussion Boards
  • Charles A.
    • July 31, 1980
    • 180
    I am trying to remove the pulley from my '67 power steering pump. Before I lean on it too much is it a regular thread or reverse thread? Also where can I get the pump rebuilt?
  • Rob A.
    • December 1, 1991
    • 2126
    Re: power steering pulley
    Chuck,
    It is regular thread. Mine was difficult to remove, and I had a friend with a pneumatic socket remove it, so I wouldn't end up chewing up the nut. It came off quickly with the air tool.
    • Charles A.
      • July 31, 1980
      • 180
      Thanks much I will give it a try.
        • 43221
        Chuck-----
        The original nut was a special self-locking type nut.
        Also, after the nut is removed, you will likely require a special puller to remove the pulley. They usually don't come off as easily as they go on.
        • Charles A.
          • July 31, 1980
          • 180
          Thanks for the info Joe. I decided to just send the whole thing to Van Steel and let them restore the whole works.
