Re: spare tire C-2 tub what size tire - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2658
    Wally,
    I used the repro BFG on an original knock-off wheel and lowered the air pressure to about 12 pounds before it would fit. The tire is still in the original tub and I did get it to close completely without too much force. I had the car judged this way and all went well. If you really want a spare that fits, you will most likely have to do what Joe did and buy a non DOT original used or new tire OR run with the repro BFG with low air pressure and carry a small air compressor just in case. I'd bet that almost every midyear Corvette out there with repro and radial tires is in the same position since there is no way the current radial tire sizes will fit in the tub either.
    Best Regards,
    James West
  • Wally A.
    • May 31, 1979
    • 170
    thanks for the input guys. bad news not mentioned. if you do get a flat on one of your pregnant tires, you would have to place it inside your car, or leave it along side the hwy....
    • Joe S.
      • July 31, 1999
      • 319
      "thanks for the input guys. bad news not mentioned. if you do get a flat on one of your pregnant tires, you would have to place it inside your car, or leave it along side the hwy.... "
      I would have to be desparate and a flatbed no where to be found within 100miles if I got a flat. ;-) AAA and a cell phone first!
