C3 BB radiator support ?? - NCRS Discussion Boards
  • Brandon Metzger
    I hve a '72 BB with AC.
    I am trying to figure out if I have the correct radiator support. If I could load pictures on this site I would but I can't so I will use Ebay.
    Is item number 4581249896 correct for my car?
    Or is item number 4580523845? Now, the one I have looks like this item. Mine has some rust wholes I was going to patch. But before I go and fix it I would like to make sure it is correct.
    Thank you all.
    Brandon
    • 43221
    Re: C3 BB radiator support ??
    Brandon------
    The support pistured in item #4581249896 is NOT the correct support for your car. The seller has it completely mis-identified. It's not even a support used for a big block application AND it's not even for the 69-72 model years. From what I can see of it, it looks like a support for a 1968-only small block application.
    The configuration of the support shown in item #4580523845 is GENERALLY the configuration you're looking for. I can't say beyond that since I can't see small details in the poor photo. However, I believe that it likely is the support used for most 69-72 big block applications (and, most all 73-76 Corvette applications, too).
    • Brandon Metzger
      Thank you Joe.
      Thank you Joe.
      I thought that first item # was incorrect. But I have had my doubts about my support. As time goes on I am thinking that mine is correct. Your bit of info here is giving me even more faith.
      Brandon
