60 doors, same as 58 doors? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 941
    I have a pair of 58 doors to replace damaged doors on my 60. They both look similar to me, will I have any problems or should I look for 1960 doors? Are door skins avaliable that will pass ncrs judging? Then I will need new date coded glass, I bought a windshield before from OEM Glass, that passed, will the side windows pass judging also?
  • Frank P.
    • April 1, 1985
    • 64
    Re: 60 doors, same as 58 doors?
    Bill
    The 58 doors are different from the 59 & 60. 58 Has a two piece door pannel with the door opening mechanism in a different position from the 59/60. If you want to put 58 door pannels on your 60, then the doors will work, but if you want the 60 door pannels you need 59/60 doors. You can also modify the locaton of the door opening mechanism on the 58 doors to receive the 60 door pannels if you are up to the challange.
