58 horn location - NCRS Discussion Boards
58 horn location
  • Randy M.
    • July 31, 1998
    • 38
    58 horn location
    Can anyone take a picture and send to me of the location of the horns? I replaced the entire front end on my 58 project and am unable to determine the placement from the assembly manual.
    Thanks, Randy
  • Ted S.
    • January 1, 1998
    • 747
    Re: 58 horn location
    Randy, Here's a couple of pics I have on the C1 Registry of my '58 showing the horn location. This one shows the approximate location from the front of the car. The second one will show where I repaired the hole from the underside and was take from the back side. Hope this helps, Ted
    • Ted S.
      • January 1, 1998
      • 747
      Re: 58 horn location - second pic
      This was taken from the back side. The center of the repair area is where the nut plate should go. It is attached on the top side of the inner fender verses this is showing the bottom side. The bonding strip shown is the one that goes between the inner fender and the header panel. This is showing the passenger side verses the first pic had the horn on the driver side. Hope this helps.
      • Randy M.
        • July 31, 1998
        • 38
        Ted - Thanks. The pics really help. Appreciate it greatly.
        Randy
