Was comparing part #'s for the L76 (365hp) and L79 (350hp) mainshafts, and notice that they're different. eg. L76 1111060 with transistor ignition uses shaft # 1964051, whereas the points ditributor 1111069 calls for shaft # 1964337. Same situation with the L79 [1111088 distr. for K66 w/shaft # 1965299; points distr. 1111087 w/ # 1964925}
I suppose it's all in the shape of the auto-cam brazed (?) to the top of the shaft, but you'd think the same engine horsepower ratings would have the same spark map. All four distrib's above use the "quick" advance 1116236 vacuum can.
But when looking at the Delco Test Spec's (DR-324S-2), it appears that the T.I. distributors' centrifugal advance comes in quicker, like around 2300 RPM, versus 3000 RPM for the points versions. In fact, the centrif. adv. for the T.I units @ 3000 are LESS than at 2300. A Delco foot-note for K66 is as follows:
"After maximum centrifugal advance is reached and distributor speed is increased above that needed to obtain maximum centrifugal advance, it is characteristic of this unit for centrifugal advance to decrease approximately 0.5 of a degree for each increase of 500 distributor RPM"
So does this mean that @ 6500 RPM, the points unit maintains about 2 degrees more total advance than the Trans Ignition unit ? I tried to check if this is compensated by different initial timing numbers (they're in the AIM for K66) but got various values for points initial timing (6 to 10 for L79; 8 to 12 for L76), depending on the source.
And does this mean that if you strip your tach drive gears, you save the auto-cam and have it re-brazed onto another new shaft ? In the re-pop arena, there seems to be just 2 shafts, one for hi-horse and the other for also-rans.
Any thoughts appreciated
