Check this engine pad - NCRS Discussion Boards
  • mike cobine
    Now are those some marks or what?
    '65 Corvette
  • Rob A.
    • December 1, 1991
    • 2126
    Re: Check this engine pad
    That's the old "non-original, hand-carved, perpindicular broach markings".
    • Harmon C.
      • August 31, 1994
      • 3228
      They go with the HCH Very Rare L@@K L@@K
      Lyle
      • Paul Reynolds
        That was a pretty rough belt sander..... I think you can see some "real" broach marks at the right upper portion of the pad closest to the head.
        • Paul Reynolds
          For what it is, that's not a bad price......Good entry level driver.
          • Rob Dame
            All it needs now are some stars and it'll be a very patriotic pad
            • Jay Garris
              You could throw a cat between those lines. But at the upcomming Barrett-Jackson it will be the RARE one of one pad.
              • mike cobine
                Well, the guy says it is a replacement engine, but he thinks it is a factory replacement, when it was probably done in some guy's single car garage one weekend.
                But like you said, somewhere, this car may show up with those "rare factory grinder marks" that proves it was a "factory fix it problem".
                • Brian M.
                  • February 1, 1997
                  • 1839
                  I wouldn't condem this pad just yet. I'd like to see factory grind outs prior to and after this example for comparision.
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Depending which computer I use to look at this picture, is that a faint 'V' I see at the extreme left of the pad?
                    Could this be another Vonawanda engine?
                    • mike cobine
                      What is to condemn? It isn't a Corvette engine, just an engine.
                      • Harmon C.
                        • August 31, 1994
                        • 3228
                        Thats why I said it goes with the HCH. Nice detective work Mike!
                        Lyle
                        • Joe S.
                          • July 31, 1999
                          • 319
                          Good eyes, except there are several previous stampings on the pad if you blow the picture up. Just to the right of what appears to be a "V" is a perfectly formed H with characters before and after..
                          Joe's 63 FI Convertible
