60 Fuel injection, 290hp? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 941
    Looking at a 60 with fuel emblems on the side, but missing origional engine and dash cluster. How can I tell if it was a 275hp 0r 290hp?
  • Mark S. Lovejoy
    Re: 60 Fuel injection, 290hp?
    Bill,
    290hp engines have a 1110914 distributor and a 1102173 generator (4.11" pulley). The distributor drives the tachometer. 250hp engines have a 1110915 distributor and a 1102043 generator (3.625" pulley). The tach is driven from the generator. 275hp engines were '61 only.
    Look for an oval shaped hole in the firewall behind the distributor, all 290hp cars had this modification.
    Hope this helps.
      • 15678
      Also the tach redline - 6500 on the 290 HP version with Duntov cam.
      Statistically, it's more likely to have been a 290 HP version (assuming the FI emblems are original) - only 100 250 HP FI engines were installed - 759 290 HP versions.
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        In addition...
        ...If the car were a low horse FI, it will have no evidence of air inlet hose forward of the air cleaner or the bracket/s that retain it, also, the rad support should still retain the round block off. If high horse FI, that block off plate will not be there and the 3 punched holes will have no sign of ever having a screw in them. Good luck, Dennis
        • Don H.
          • December 1, 1981
          • 1487
          Re: In addition...
          I have a '60 low HP FI and it does not have the round air block off plate in the radiator support. Don H.
          • Dennis C.
            • January 1, 1984
            • 2409
            Maybe somebody removed it...???...
            ...3 screws would do it... ???
            • William B.
              • April 30, 1975
              • 941
              Re: Maybe somebody removed it...???...
              There is no block off plate and the holes look untapped. Should there be a screen there like on the other side?
              • Dennis C.
                • January 1, 1984
                • 2409
                Bill, No screen on LH side...
                ...should be a solid sheet metal round plate. DC
                • William B.
                  • April 30, 1975
                  • 941
                  Re: Bill, No screen on LH side...
                  There is a hole, no plate, no screen and no tapped holes?
                  • Mike McKown
                    Wrecked
                    replacement radiator support?
