C2 1966 Fiberglass holes - NCRS Discussion Boards
  • Robert T.
    • May 31, 1993
    • 346
    I have a question regarding the correct amount of holes that should be in the lower fiberglass piece that runs below the grill opening. The holes I'm talking about are used to mount the support rods that also attach to the bottom of the core support. (hope that makes sense, sorry). Any way, I know the BB and SB core supports are mounted at a different angle and thus would use different hole locations in this fiberglass piece. My question is, should there be 2 holes, one on each side or 4, 2 on each side, 1 set for the BB location and 1 set for the SB location. My quess is that this fiberglass piece is generic and would have 4 holes, you just use the correct ones per your installation. This all has to do with the correctness of an after market piece. I appreciate it if some C2 owners could take a look at their cars in this area. Thanks for the help.
    Bob
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: C2 1966 Fiberglass holes
    My 67 BB has 4 holes. The forward 2 holes are bolted to an "L" bracket which attaches to the core support. There is also a cutout on the passenger side.
    • Robert T.
      • May 31, 1993
      • 346
      Thanks for the quick response Steve. That's one validation of my thought, i.e. 4 holes. Funny you should mention the cut out. THe fiberglass guy asked if I wanted a "cutout" added. I wasn't sure of the details so for now I told him no, for now. I'll have to research when this cutout started showing up. I don't want to impose, but any chance you could send me a picture of yours. Thanks again.
      Bob
      • Rob A.
        • December 1, 1991
        • 2126
        Bob,
        Four holes, 2 each side on the original panel on my '66
        • Steve Pettit
          2 each side on early 66.
          • Robert T.
            • May 31, 1993
            • 346
            Thanks Rob. Do you have the cutout that Steve talked about in his response? Thanks again.
            Bob
            • Ian S.
              • June 30, 2002
              • 264
              Notch photo *NM*
              • Ian S.
                • June 30, 2002
                • 264
                Notch photo 2 *NM*
                • Gerard F.
                  • June 30, 2004
                  • 3806
                  My 67 SB has 4 holes, and I took a deduct on the extra holes. However, I was missing the two bolts to the radiator core, so I didn't make a fuss.
                  Jerry Fuccillo
                  #42179
                  Jerry Fuccillo
                  • Robert T.
                    • May 31, 1993
                    • 346
                    Getting some great responses. Thanks to everyone. It sure sounds like 4 holes is the correct number. I was surprised to hear the Ian got a deduct for it though. Actually, I'm not too surprised, judging and judges vary a lot. Thanks for the great pictures of the cut out too.
                    Bob
                    • Robert T.
                      • May 31, 1993
                      • 346
                      Sorry, I guess it was Jerry who got the deduct. Sorry Ian.
                        Re: C2 1966 Fiberglass holes - Another Photo
                        Here's a photo of my '67 showing the cutout and depression in the panel on the passenger side.
                        • Robert T.
                          • May 31, 1993
                          • 346
                          Thanks John. That's perfect. Thanks for going to the extra effort to help me out. And again thanks to everyone else for your help.
                          Bob
                          • Wayne W.
                            • April 30, 1982
                            • 3605
                            Both the holes and the cuttout showed up in 66 with the change in radiator support angles.
