67 fan blades - NCRS Discussion Boards
67 fan blades
  • larry linkous
    67 fan blades
    What type of fan blade would have been on a 67 427 with air conditioning?/ It was built in May. A five blade or a seven blade. Also any part numbers on the fan itself?/ Thanks Larry
    • 43221
    Re: 67 fan blades
    Larry-----
    It was a 5 blade fan of GM #3888366. This fan blade assembly was used for ALL 1967 4272. The part number is NOT found stamped on the blades. This piece was discontinued about 30 years ago and replaced by a 7 blade fan of GM #3955182.
    • larry linkous
      Thanks Joe!!!!!!!!!!!!!!!! *NM*
      • Peter L.
        • May 31, 1983
        • 1930
        Re: 67 fan blades
        Larry - To add to Joe's response, the 3888366 fan blade assembly was used on both non- AC and AC '66-'67 427 Corvettes. Examples I have seen that 66 stamped on the center of the support piece. I have been told that not all of these fan blade assemblies have the 66 stamping, so if they came either way, you'll need to know exactly what you're looking for. They come up on eBay every once in a while. Also, Long Island has a reproduction. Pete
