Gentlemen:
What is the correct procedure fro removing the pedal from the rod that is mounted to the firewall? I ma trying only to remove and replace the pedal and chrome trim. There is a spring on the reverse whihc keeps tension on the pedal and a pin that secures the actual pedal to the rod and the pin APPEARS to be a press fit but I cannot get it to thread out or move. Any suggestions as my 10 pound sledgehammer will not fit under the dash to get at this pin to "fine tune" it. I thought this would be a quick 5 minute remove and replace task.
WRONG
Kurt
WRONG
Kurt
