heat resistant radiator paint - NCRS Discussion Boards
  • Tony DiGiorgio
    Hell all, is there such a thing as heat resistant radiator paint? just got rad back from shop and needsw finishing touches, dont want anyhthing that will flake off after couple of uses. Your experience is appreciated.
    Tony DiGiorgio
  • Mike M.
    • May 31, 1974
    • 8391
    Re: heat resistant radiator paint
    VHT makes high temp engine paints in varoius colors including gloss black. used it for years. radiators don't reach the operating temps that engines do. your radiator will love it. mike
      • 11644
      I use the radiator paint available from Eastwood. Just the right gloss and thickness. It's nice stuff!
      • mike cobine
        Spray it on thin
        The purpose of a radiator is to radiate heat. The more paint, the more it will hold the heat, so don't put a dozen coats on to make it look good.
        • paul bowers
          Mike is right
          when i had a new radiator put in my 57 the shop did srpray the core with a paint ,but a special paint , so not to interfere with air flow
          paul
