C-1 Transmission Seal - NCRS Discussion Boards
  • Dwight B.
    • April 1, 2004
    • 25
    Any suggestions as how best to remove rear oil seal from 1958 T10 4/spd ? The old pry it out with a screw driver approach is not working. Also, should oil seal have a felt packing ? my old oil seal does but my replacement from Corvette Central does not.
    thanks
    Dwight
  • John O.
    • May 31, 1998
    • 480
    Re: C-1 Transmission Seal
    Hi Dwight
    There is a tool out there in the auto parts stores thats used to pull front seals.Cost is between $10 - $20. I do believe it will work for the tranny seal. As far as the packing, the new seal does not use it. I see no need for it.
    John
    • Dwight B.
      • April 1, 2004
      • 25
      John, thanks for the info. on the seal packing. I kind of thought that the new design did not call for packing. I agree with you that it is hard to see it's utility.
      As to removing the seal I believe that who ever installed the seal must have used gasket compound or some sealant during intallation. It will not budge and I have used a slide hammer to no avail. All I have been successful in doing is destroying the metal around the seal. Do you think that removing the tail piece might allow me to drive it out from the inside ? hard to tell by viewing from the outside but it does not look like that will work either.
      thanks
      Dwight
      • Rob Dame
        Try taking a long screwdriver with a small flat end and tap it in-between the seal housing and the tailshaft. This will collapse the seals outer edge and it should pop right out. Rob
