1964 body mounts - NCRS Discussion Boards
1964 body mounts
  • Ralph Harvey
    1964 body mounts
    I have a Nov. built 64 and wish to change out the original body mounts. My information says that there are 3 body mounts per side. One just behind the front wheel, the next one just forward of the rear wheel and finally one just behind the rear wheel. Does this seem right ?
    Thank You
    Ralph Harvey
    #28843
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 1964 body mounts
    If its a coupe that's correct. Those points have rubber bushings as part of those positions. You also have a mount position under the radiator core support. This position does not contain rubber bushings, only shims.
    If you have a convert there is an additional body mount under the door sill which also has rubber bushings.
    • Ralph Harvey
      Steve
      Thank you for the info. Yes, it is a coupe .
      Ralph
