C-3 Headlamp Door Adjustment - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Gentlemen:
    Is there a mechanism or a "stop" that can be adjusted for positioning the headlight doors when in the closed/down/off position. I know there is such an adjustment for the doors when in the "UP" (on) position but one of my headlamp doors on my 68 would line up better if it were raised 1/8 inch when closed. In other words, when closed it is recessed 1/8 inch and I would like it to be flush with the surrounding area.
    Thank you in advance,
    Kurt # 26406
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C-3 Headlamp Door Adjustment
    Kurt
    The adjustment is a threaded bolt and on the end is a small hex 1/4" or less.Use a small socket to adjust. It is located on the pivot point. Lyle
    Lyle
    • Kurt B.
      • July 31, 1996
      • 971
      Lyle,
      Thank you very much for your reply.
      In what vicinity will I find this threaded bolt?
      Kurt
      • Harmon C.
        • August 31, 1994
        • 3228
        Kurt
        It is in the center between the springs. Looking up from under the car with the head lights down you should see it. The threaded bolt is thru a white L shaped casting and may be hard to move with the hex being smaller than the threads. The other end of the bolt has a regular hex head. Lyle
        Lyle
        • Kurt B.
          • July 31, 1996
          • 971
          Thank you Lyle *NM*
