'67 crankshaft pulley with A/C and P/S - NCRS Discussion Boards
  • Barbara S.
    • April 30, 1981
    • 599
    Can someone tell me if a '67 small block crankshaft pulley with A/C and P/S is 3 groove or 2 groove?
    Thanks!
    Tony
  • Gerard F.
    • June 30, 2004
    • 3806
    Re: '67 crankshaft pulley with A/C and P/S
    Three grooves with P/S and A/C. P/S is the third position.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
      • 43236
      Jerry and Tony------
      It may APPEAR like 3 grooves, but it's actually 2 pullies "sandwiched" together----a 2 groove pulley and a 1 groove pulley. No Corvette ever used a 3 groove crankshaft pulley-----no big block, no small block, and no medium block.
      The only Corvettes that EVER used a 3 groove pulley of ANY type were 68-74 big blocks for the waterpump pulley (except L-88/ZL-1).
      • Barbara S.
        • April 30, 1981
        • 599
        Joe. So, is it the regular 2 groove pulley that would be used for the alternator and A/C, then an additional single pulley in the forward position for the p/s?
        Does the added single crankshaft pulley have the same diameter as the 2 groove crankshaft pulley?
        Thanks.
        Tony
          • 43236
          Tony-----
          The 2 groove rear pulley, GM #3850838, is 7-21/64 OD. The single groove front pulley, GM #3751232, is 6-11/16" OD.
