1966 power antenna - NCRS Discussion Boards
1966 power antenna
  • Hector G.
    • November 1, 2004
    • 234
    1966 power antenna
    Here are some photos I took of my 66 vette's antenna. It does not appear to be an original 66 antenna. Does anyone know if this is a corvette antenna and what year. Could it be an after-market replacement? It has been on the car for at least 21 years. Thanks for your help.
    Hector
    PS I'm new at posting photos and couldn't figure out how to post several photos together. I've included the other photos in separate posts. Sorry. If anyone knows how to accomplish this, let me know.
  • Hector G.
    • November 1, 2004
    • 234
    Here's another photo *NM*
    • Gary B.
      • February 1, 1997
      • 7023
      1966 antenna tip
      Hector,
      The tip looks like the tip on the GM service replacement antenna that was installed on my '66 back in the late 1960's.
      Gary
      • Mike M.
        • September 30, 1999
        • 710
        Re: 1966 antenna tip
        There should also be rings on each mast section. Mike
        • Greg T.
          • January 1, 2004
          • 136
          Re: 1966 power antenna
          There's a real antenna on E-bay #4578158886. Yours isn't even close.
          • Hector G.
            • November 1, 2004
            • 234
            I was more interested in knowing if someone could ID this antenna. As one of the previous comments indicates, it may have been a service replacement.
            • William C.
              • May 31, 1975
              • 6037
              Typical of GM service antenna from the early 70's
              Bill Clupper #618
              • Wayne M.
                • March 1, 1980
                • 6414
                I've got one exactly the same
                As Bill C. says probably a GM replacement not long after the stock of originals was exhausted. Once removed from the car, you will notice that the bottom mounting stud is in line with the shaft, not off-set as are the originals. You must fabricate an intermediate bracket to use the original mount hardware. Also, almost impossible to use the original ground plate, as there's not enough projection on the top of the body for the threaded chrome nut.
                Works like a damn, though -- much better than the original.
                • Hector G.
                  • November 1, 2004
                  • 234
                  Thanks for the info Bill.
                  • Hector G.
                    • November 1, 2004
                    • 234
                    Re: I've got one exactly the same
                    Thanks Wayne.
