C2/C3 Aftermarket rear spring bands - NCRS Discussion Boards
  • William V.
    • December 1, 1988
    • 399
    All the aftermarket springs I have seen come with the bands around the leaves. The original c2/c3 rear spring did not have said bands. Has anyone removed the bands? And if so, were there any problems?
  • Dick W.
    • 10483
    Re: C2/C3 Aftermarket rear spring bands
    No problems removing bands. They were designed to keep the springs in alignment prior to installing.
    Dick Whittington
    • Gary B.
      • February 1, 1997
      • 7023
      Rear spring bands
      Bill,
      If you used the correct H-shaped liners between the leaves and the bolts near the center and ends are correctly tightened you will be fine without the bands.
      Gary
      • William V.
        • December 1, 1988
        • 399
        Dick, Gary Thanks *NM*
