60 hardtop questions - NCRS Discussion Boards
  • Don Izzo
    Just pulled out my hardtop that cme with the car wen purchased. It is in bad shape and I am considering a restoration but dont want to send it out. Are the mouldings on the inside stainless or chromed? Mine have a light covering of rusty spots covering them from end to end. If chromed I am sure that I can lightly polish or grind them out before plating, if stainless I may need to replace them if they leave pits. Are they readily available? All the windows are original with mfg. markings and date codes however they are hazey.No major scratches or cracks. I was able to clean a small spot with "neverdull" but was wondering if there is a better product I could use? Has anyone repolished the plastic windows with a buffer? Is this a good idea? Also found that the center moulding at the lower rear that joins the two halves is missing. Can this be gotten?
    Don
  • Jerry C.
    • November 1, 1995
    • 741
    Re: 60 hardtop questions
    Call Ted at Auto Entec 888-340-7812. He will have all of your answers.
    • Roy B.
      • February 1, 1975
      • 7044
      Inside S/S you sand light pits out and Polish, windows wet sand and Polish
      • Don Izzo
        Thanks for the quick responces. I don't want to get involved with the people at glassworks if I don't absolutely have to.
        Don
