'66 CONVERTIBLE WATER LEAK - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    After washing my car, when I drive it water leaks onto my feet on the driver's side. It doesn't leak while sitting still. Where would be the first place to look to find the cause? I checked the archives under water leak because I remember seeing a posting regarding this recently, but couldn't find anything,
    Re: '66 CONVERTIBLE WATER LEAK
    Rob -
    Generally, the drip-on-your-foot leaks come from two places - either through the cavity under the wiper grille (usually a bad seal where the wiper transmission goes through it) or through rust holes in the bottom of the windshield frame.
    • Peter L.
      • May 31, 1983
      • 1930
      John - Darn, so there are causes for the water leaks. I thought the the water leaks were a RPO !!!!!!!!!!!!!!!! Pete
      • John L.
        • 409
        Peter -- actually you are correct. It was RPO H20
