Can someone refresh me on how to determine the.... - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    assembly date of my engine. Thanks, Terry
    • 43221
    Re: Can someone refresh me on how to determine the
    Terry------
    It's very easy, assuming that the engine pad stamping is intact. The month and year are coded after the plant code (i.e. "F", "V", "T"). Something like "1215" would mean the December 15. For the year, you have to go to the engine casting date and figure the assembly year consistent with the casting date.
    Of course, this only tells you the ORIGINAL assembly date of the engine. The engine may have had numerous subsequent "assembly dates" not recorded or coded anywhere.
    • Terry F.
      • 2061
      I knew it was something along those lines. Thank you, Terry
