early 61 trans - NCRS Discussion Boards
early 61 trans
  • Leon Brown
    early 61 trans
    Early bw trans with a t10-1b cast iron case and t10-7b die cast aluminum tail housing. Input has 3 rings. What is the gear ratio of this trans.
    Regards
    Leon
  • Donald L.
    • September 30, 1998
    • 461
    Re: early 61 trans
    Wide ratio-2.56-a.91-1.48-1
    Close ratio-2.20-1.66-1.31-1
    • Leon Brown
      Re: early 61 trans
      can you elaborate on this. Rookie here.
      • Donald L.
        • 461
        Re: early 61 trans
        First Seond Third Fourth
        2.56-1 1.91-1 1.48-1 1-1 Wide ratio
        2.20-1 1.66-1 1.31-1 1-1 Close ratio
        • Leon Brown
          Re: early 61 trans
          I guess my question is: How do I determine wide or close ratio?
          thanks
          • Donald L.
            • 461
            Re: early 61 trans
            If you have your trans out shift into first gear.Mark a spot on the output shaft side.
            Turn the input shaft gear till the output shaft turns once. If it takes 2 1/5 turns for one turn of the output shaft its a close ratio trans. A wide ratio trans will take 2 1/2 turns to one yurn on the output shaft.
              Re: early 61 trans
              If it's an original '61 Corvette transmission, it'll be the close-ratio version; the wide-ratio version wasn't introduced until 1962.
              • Leon Brown
                Re: early 61 trans
                What distinctive markings is there on a vette trans vs. a chevy passenger trans?
                thanks
                Leon
