1982 CE alarm - NCRS Discussion Boards
1982 CE alarm
  • David K.
    • August 31, 2002
    • 62
    1982 CE alarm
    Is there a good place to start looking for the problem when the alarm on a 1982 Collectors Edition does not work? It will not set and does not trip the alarm from any area (Hood, door, t-top, etc). Is there a common problem with these alarms? There are no other electrical problems with the car that I am aware of at this time.
    No fuse problems that would have been too easy.
    Is there a way to test the Theft Deterrent Control Module?
  • Donald Brunswick
    Re: 1982 CE alarm
    David,
    No way to test alarm module, best is to find a know working one and swap. I had the same problem and had a heck of a time tracking down the issues all switches etc worked but it came down to a faulty passenger door pin, even though out of the car it checked out fine. Good luck tracking it down.
    donald
    • David K.
      • August 31, 2002
      • 62
      Re: 1982 CE alarm
      Did the faulty door pin cause it not to work at all, with any of the other areas?
      • Donald Brunswick
        Re: 1982 CE alarm
        Yes the fault pin caused it not to work at all.
