C2 Side Exhaust Fiberglass Question - Photo - NCRS Discussion Boards
  • Ken K.
    • May 31, 1999
    • 235
    This photo is of right rear wheel opening of a 1966 corvette. My question is: The fiberglass body part that is circled in red, is this correct? Is it correct of a side exhaust car, non-side exhaust car, or both models? I seen a few Corvette had this part without that radius in the lower right hand corner of this flap. What is the differance? Thanks
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: C2 Side Exhaust Fiberglass Question - Photo
    Its on my 67 sidepipe car. Its also on a non sidepipe but possibly without the curved cutout... really haven't payed much attention.
    • Bill Stephenson
      Keen,
      ------Others will post as well, but its my thought, and I could be wrong, that the radius cut does not have quite the right radius. There is more of a curve to that cut. Also, that cut is usually a bit rougher along the edge, usually being the optimum word!..........Bill S
      • William V.
        • December 1, 1988
        • 399
        Ken
        According to the AIM the radius is to be cut at 3.5" with 0.5" lip at the inside bottom of the inner fender
        • Rob A.
          • December 1, 1991
          • 2126
          Ken,
          The straight, inner edge you circled in red is correct for a non side exhaust car. The slight radius on the bottom should be straight also for a non-side exhaust car. Factory side exhaust(or those properly converted) have a larger radius curout on the bottom that removes uite a bit of the inner and bottom edge. There's a good picture of it in the assembly manual and Noland Adam's book, page 296.
