68 rag joint question? - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    The rag joint on my car looks correct except that there are two rubber bumpers slid over the two posts that limit how far the rag joint can flex. Has anyone else seen this before? It also has a flat copper stap that runs through the middle for grounding purposes. Thanks, Terry
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 68 rag joint question?
    THe rubber bumpers are correct as is the grounding strap
    • Terry F.
      • 2061
      There is a guy on ebay advertising a 68 corvette rag joint. I was looking at it and that is how this all got started. It is completely riveted together. Mine is identical but has two nuts and two bolts. I have seen the rebuild kits and mine is not like that at all. Just wondering, Terry
