Ok, following up on a previous discussion today, I set the total timing at 36 degrees advanced as follows: took the springs off of the distributor, marked the balancer at 36 degrees, started and warmed up, revved to max advance, adjusted 36 degree mark to zero, tightened distributor hold down, bumped several times to make sure there was no additional advance. Then I put the springs back on, started it, set the idle at 800 and checked the initial timing: 2 degrees retarded. I then checked a few more points to see (approximately) what the curve looks like: -2 @ 800, 3 @ 1000, 8 @ 1500, 15 @ 2000, 20 @ 2500. Looks like the curve needs a lot of work.
Steve
Steve
