C-1 Wheel Question - NCRS Discussion Boards
C-1 Wheel Question
  • Anthony F.
    • December 1, 1985
    • 191
    C-1 Wheel Question
  • Chris H.
    • April 30, 1990
    • 817
    Re: C-1 Wheel Question
    note on drawing 3723561 says
    "valve hole must be within spoke area. Relation to bolt hole unimportant"
    Thi note was on the drawing before 4/12/62 (drawiing redrawn) but may have been added/revised sometime after 12/27/54 when the drawing was first released.
    Could you tell me the dates on all your wheels and whether they have rivets/welds/dogbones/double hump(extra hump around the center raised reinforcing hump). I want to see if my chart agrees.
    Thanks, chris
    • Anthony F.
      • December 1, 1985
      • 191
      Chris,
      Thanks my friend but I do not have the dates recorded and all wheels have tires mounted on them.
      I believe that I have some extra riveted wheels in the shed. I will check to see if I can locate those dates for you.
      • Anthony F.
        • December 1, 1985
        • 191
        • Chris H.
          • April 30, 1990
          • 817
          The chart I made up only covers 5" corvette wheels.
          The dates on my wheels were very hard to see until I had them stripped.
          Does anyone know if the wheel seals were used in non vette applications? Vettes used them from mid 55 to '58 and possibly some '59.
          From what I can find in books, vettes used riveted wheels from '53-early '56, (generally welded statement in the 56/57 JGM's).
          Colvin also states that passenger car shared wheels with vette from '53-'57.
          My chart needs to be confirmed with actual wheel inspections before I am comfortable with it. The biggest issue is when riveted vs. spot welded wheels were used. I believe that in normal production rivets were used from '53-'early '56 and then a change to welded was made.
          From your description your wheels may be correct for '55-early '56. Seals were used for both those years on vettes. I have 3 of the same wheels that were on my 62 and they were shared with passenger so they are probably very common.
