C2 part #s, pulleys, starter, distributor - NCRS Discussion Boards
  • Bill Farmer
    Hello everyone, as some of you may know from my earlier posts, I am moving to Germany in April. Well, I am trying to get my car put back together asap. I visited my parts the other day at the engine builders and wrote down some #s. Someone tell me if these are correct, as I am trying to replace as much wrong stuff before I leave.
    pulley 3906656
    pulley 3903644 DB
    starter relay 951 D9-5
    starter 1107365 6 E 16 Delco Remy 2BA
    distributor 1111093 Delco Remy 6 C 21
    I have a 66 L72. Thank you all for your help Bill#44207
  • William C.
    • May 31, 1975
    • 6037
    Re: C2 part #s, pulleys, starter, distributor
    Pulley 3906656-66 427 water pump
    Pulley 3903644 -66-70 427/454 not SHP, but may be service replacement
    Starter sol-sounds correct, starting motor and dist both look correct based on the dates and the part numbers are correct.
    Bill Clupper #618
      • 43221
      Bill-----
      The GM #3906656 and GM #3903644 are not likely to be the original pullies used for your car. These are 1967 pullies that later became SERVICE for 1966. If your car were a VERY LATE 1966, then I'd say it's POSSIBLE that these were original. However, I doubt it.
      • Bill Farmer
        Joe, my car was born in late May 66. Is that late enough?
          • 43221
          Bill-----
          I sort of doubt it, but I would not rule it out completely.
          • Bill Farmer
            Thanks Joe. The water pump is a replacement but the power steering pump is original. I guess I have a 50/50 shot. Thanks again. Bill
