c1 radiator support question - NCRS Discussion Boards
  • James B.
    • September 30, 2005
    • 115
    If I remember correctly, all radiator supports are the same from '56-'60,right? It's the 61-62's that are different?
    Jim Brady III
    1959 Corvette Registry, Webmaster
  • Loren L.
    • April 30, 1976
    • 4104
    Wrong. At the very least, HP '60's use
    a different support, with the drain on the LH side.
    • James B.
      • 115
      Re: Wrong. At the very least, HP '60's use
      Thanks Loren- Sounds like I have some more homework to do..
      Jim
      • Wayne P.
        • August 31, 1975
        • 1025
        Re: c1 radiator support question
        The 56/57 have different hood hinge mounts.
        • Tom Wander
          For a '60 there are two styles of supports - one for the brass radiators and one for the alum. top-tank radiator.
          Tom
          • John M.
            • January 1, 1999
            • 1553
            And, as Tom and I found out the hard way, there is also a different hood for each of the two supports! You can not put a copper radiator support hood an an aluminum radiator support car. There were still 59 style hoods being used on early 60 cars that had the copper radiator until they were used up, and then the new 60 style hoods were used.
            Regards, John McGraw
