PS pump pulley - NCRS Discussion Boards
PS pump pulley
  • James Kennedy
    PS pump pulley
    I need a pulley for my PS pump but I noticed that the pulley for the L79 is significantly more expensive than the base engine PS pulley. Does anyone have any suggestions on another pulley besides the original one (for an L79) that will bolt in place of the original?
    • 43221
    Re: PS pump pulley
    James-----
    Basically, there were only 2 different power steering pump pullies used for most 1963-74 Corvettes (there were actually a few others, but these had very limited application). Most 1967 L-79 used a "drop down" style, cast iron pulley of GM #3878245. Many other small blocks used a stamped steel, "pancake" style pulley of GM #3770509. The pullies are both GM-discontinued but available in reproduction.
    The above-referenced pullies are NOT interchangeable. They are specific to the particular pulley system used on a specific engine.
      • 43221
      Correction
      I should have said that there were, basically, only 2 different power steering pump pullies USED FOR 1963-74 SMALL BLOCK APPLICATIONS. A different pulley was used for big block applications, with only this one pulley used for ALL 1965-74 big block with power steering applications.
      • Paul Reynolds
        Re: PS pump pulley
        Yup, the L79 P/S pulley is a bit more expensive. Probably because it's a cast iron piece vs the stamped steel one for other applications. Aside from the cost, it IS the correct pulley for your application. If you try to come up with a different solution, you'll end up spending more money in additional pulleys to get things lined up.
        • James Kennedy
          Re: PS pump pulley
          Thanks for the tips...Ill get the right one. Just wanted to check.
