Re: Save yourself a lot of trouble
You say you have a big block with air and your last post said you were pulling the heads next. I don't know if you can even get the right head out with the air box in there. I know I can't get anything big enough to get the bolts out on my 427 with air. I don't think I can get the right exhaust off of mine.
If you aren't pulling the heads, then keep the engine in.
Still, it seems extreme, but for most things, you can have it out with a little over 2 dozen bolts and have it where everything is easy to fix.
It mainly depends on what you are taking off.
