I just bought a rebuilt non HEI distributor for the 350 in my '59 Vette. I plan to check this distributor on a machine before installing it. What should the curve look like?
I believe the 350 is out of a '70 Vette, It has high compression (200# in every cyl), has a mild roller cam and an alum intake from a '64 Vette. The oil fill cap in the intake is the vented type and there is a pcv valve in one valve cover. The engine produces about 12 to 14" of vacuum at about 800 rpm. The vac can on the rebuilt dist has the numbers 446 15 stamped on it.
Recommendations of degrees of advance at certain rpms, and a vac can will be greatly appreciated. Thank you in adavnce (no pun intended). Pat G.
