59 window felts - NCRS Discussion Boards
59 window felts
  • John C.
    • September 30, 2001
    • 130
    59 window felts
    Is this a major job, can someone tell me how to install the felts. Thanks
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12789
    Re: 59 window felts
    John,
    It is a terrible job to put the staples is (actually to drill the needed holes since once you start drilling the SS tense to harden due to the heat of the drill). You could cheat and glue/kit them in and the glue some backs of the staples on the felt but I don't believe you would get away with it ;-0
    This is one of the jobs hy on my terrible job list:
    1) remove and attach the left wiper transmission
    2) drill the stample holes to attach the window felts
    3) disassemble anything behind the dash (especially because I'm to lazy to remove the chair runners
    4) remove and fit the lower radiator hose (without taking the lower fan-shroud off)
    5) remove and attach the waterpump
    greetings,
    Rob.
    Rob.
    NCRS Software Developer
    • Ed Jennings
      Re: 59 window felts
      You can carefully mark the original staple holes on the new felts, but it is a painstaking task. After doing many sets this way, on the last ones I installed, I gave in and used small pop rivets. Not NCRS correct, of course.
      • Don Izzo
        Re: 59 window felts
        Funny but I never found this job to be that difficult on my 60. after lining up the original holes, I clamped the new felts to the reveal mldgs, and then drilled through the old holes using my drill press and high quality drill bits. Never cared for cheap drill bits, buy the best and you will find all your boring chores go much easier! Maybe that was the secret to my easy sucess! I don't recall if I used "C" clamps or small vise grips to hold the felts in place. Either way will work just fine. Use only as much pressure on the clamps as necessary to hold in place or you will mar the surface of the felts. You could probably use small pieces of wood or plastic between the felts and the clamps to protect the felts.
        Don
        • Dennis A.
          • April 30, 1999
          • 1010
          Re: 59 window felts
          Some Hints....
          Crush the felts in a vise, this will prevent a tight fit. Crush the curve section to prevent "bulging".
          Postion the felts into the door post front run, mark this location on the molding.
          Mark the staple hole positions, using a right angle pick inserted thru the felt.
          Apply a thin coat of two part epoxy and hold into position. Clamp the inner garnish at the ends, this will prevent the window glass frame from tearing into the felt during roll up.
          Insert the staples for looks/judging.
          Note the outer reveal molding can be chrome flashed after polish for a great looking job.
          I'm sure the General would have used an epoxy if it were around in '59.
          • Geoff C.
            • May 31, 1979
            • 1613
            • Bob Simard
              Door Felts
              On my 60, I just clamped the ends together in the proper location and hammered a small brad thru the exist hole and thru the felt. Install the staple in these holes and do the other end. After that, the staples in the middle are easy.
              • Robert C.
                • November 1, 1993
                • 34
                Re: 59 window felts
                John,
                Make sure the beads are positioned just above the reveal molding otherwise the
                window will be too tight.Get this position right before any drilling.
                Robert
