Intake Manifold Pins - NCRS Discussion Boards
  • Al Detmar
    Can anyone let me know where I can obtain the steel pins that fasten the heat shield to the underside of the intake manifold for a 1968 Corvette 327 engine?
    I had to remove it in order to take out a significant carbon buildup.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Intake Manifold Pins
    This question has been asked before. I believe the recommended repair is to tap and use a screw to hold the heat shield in place.
    • Steve Antonucci
      Al,
      Stick with the screws for the assembly of the heat shield. It's not worth the
      pain and $$ you'll suffer if one of those little studs comes loose and gets
      into the rotating assembly. I was rustling over this very issue when I
      recently restored an L/71. Glad I went with the screws. You will be too.
      Steve
        • 43259
        Al-----
        In my opinion, the best thing is to tap the holes for machine screws and install same with Lock-Tite high temperature thread locking compound. However, if you wish to use the studs, you can obtain them under GM #10229247. NEVER reuse old studs unless you install them with thread locking compound. Even then, I would recommend using new studs rather than used ones.
        • Christopher R.
          • March 31, 1975
          • 1599
          I believe that when you go to buy this part number from Chevrolet, that there's a big minimum buy. Believe that they come in packages of 5 and that the min buy is 10 packages. I looked up this p/n some time ago. Not sure I'm remembering correctly.
          • Mike Geary
            Al: go to EBAY and search "intake manifold heat shield rivets".
            DelrayDoug sells them in batches of 10 for about $5.
            I swab a little JB Weld on the spiral shanks when installing, just for peace of mind.
              • 43259
              chris-----
              Unless the dealer you get them from actually stocks this item, they will want you to purchase the package quanitiy of 10 studs. That's enough for 2-1/2 manifolds.
                The 10229247 "Pins" come ten in a bag, and you can order just one bag; the O.D. of the (very sharp) splines is slightly larger than the originals, and they work fine. I've used them on several intakes with no concerns.
