Brake System Problem , Revisited - NCRS Discussion Boards
  • Jerry Clark
    Hello Everyone:
    For those of you interested and remember my post regarding the 65, 365 collection car with the brake system problem,(all four corners locked after a silicone conversion), the solution was found and fixed and as most surmised it was the brake master. It was explained to us that glycol based brake fluid has a better lubricating profile than silicone and problem areas that my not make themselves obvious with glycol can quickly surface with silicone. This appears to be true in this instance. The master was taken apart again, honed and resealed, (a VERY slight burr was observed on the piston), The sequence of events indicates that while this system functioned with glycol it wouldn't with silicone. While several parts were replaced and rebuilt the master cylinder and its imperfection combined with the silicone was the culprit, live and learn I guess. Given this, much more attention will be paid to these components next time a conversion takes place, today, I think.
    jerry
    • 15601
    Re: Brake System Problem , Revisited??
    Jerry,
    I'm curious - did you keep the DOT 5 or go back to Glycol based fluid?
    terry
    • Jerry Clark
      Hi Terry:
      We stuck with the DOT5, Jack felt he had gone through all of this in the interest of the conversion and he wasn't about to let it get the better of him, good man Once the master was cleaned of imperfections, no problem however we are certain that the system functioned with the burr on the piston while filled with DOT 4 but the DOT 5 wouldn't.
      jerry
        • 15601
        Thanks Jerry.
        I don't want to start another big deal here - we have been over this too many times. I just like DOT 5. All I can say is it works for me in the Corvette. NOT for daily drivers though. Just my 1% of $2. (Ducking the flames in my Nomex FR clothes.)
        • Jerry Clark
          Terry:
          The DOT5 is the only thing to use on cars that are stored for long periods...period
          jerry
