68 SB Carb and VIN Post Color - NCRS Discussion Boards
  • Dennis M.
    • April 30, 1988
    • 160
    I have two questions for an early 12/67 1968 Conv. First the correct quadrajet for this application is listed as 7028208, however I believe the carb in this car is WRONG, I can't be sure because I have looked at every posible location on this Rochester Quadrajet for any numbers and there are NONE. Were replacements un-stamped?
    Question two is regarding the windshield post where the VIN plate is located. I have looked at several color combination and they all appear to have this area on both sides paint a flat black, however after removing the cracked windshield I found the VIN plate to have traces of the interior Bright Blue paint. Now the more I look both posts are painted in the interion color of Bright Blue. Were these painted the interion color and then some portion paint a flat of semi-flat black? If so does anyone know how the process was done. Naturally this would have been done during the painting process and before the windshield was installed.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 68 SB Carb and VIN Post Color
    early Q jets had the carb # on a small aluminum round disk embedded it the side of the carb and these fell out or were removed on most i ever worked on. i am not sure when GM went to the stamped number on the drivers side that is stamped above the secondary throttle shaft
    • Kurt B.
      • July 31, 1996
      • 971
      My 68 built on May 10 has the number STAMPED on the carburetor but I don't know when they started the stamping in lieu of the disk.
      Kurt
      • Dennis M.
        • April 30, 1988
        • 160
        Thanks Clem and Kurt, Did anyone have any input as to the color found on the windshield pillar and specifically the VIN plate?
          • 15621
            • 11681
            Take a look at my 72 this weekend. (Like you won't be...)
            It has a nice stripe of Sunflower Yellow near the top of the front windshield posts.
            Patrick
              • 15621
              What, they missed a spot. I'm horrified.
                • 11681
                You should have seen John Ballard at Seven Springs in 2003 trying to figure out what it was.
                Patrick
