Frozen Heat Riser - NCRS Discussion Boards
Frozen Heat Riser
  • Gary #41345
    Frozen Heat Riser
    If a heat riser gets frozen up the effects on the engine will be?
  • Tom D.
    • September 30, 1981
    • 2132
    Depends If open, shut, or half open...
    If open, not a problem until you start up in winter. Engine warm up will be slower.
    If shut, right side exhaust is always forced up and through the intake, even after the engine is hot. This which will overheat your carb. Fuel in the carb will overheat (perhaps boil?) and performance will suffer. How severe? Depends which intake you are running.
    If half open, you get half of the above "if shut" problem.
    One out of three makes for poor odds. Fix it, or replace it. If you can free it up, wire it open to see the effects of "if open". Weight on the outside should point to the ground when open.
    Tom
    4889
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Jim T.
      • March 1, 1993
      • 5351
      Re: Frozen Heat Riser
      The muffler/exhaust system on he passenger side will last longer if the heat riser is wired/frozen open. Heat risers restrict the hot exhaust from removing the moisture from the muffler.
      • Gerard F.
        • June 30, 2004
        • 3803
        Gary,
        Try some Tri-flo on the shaft. Not sure how long it will last but it did free up a brand new one on mine from sticking in a half open position. They don't fully open with heat alone, but are supposed to go fully open with exhaust pressure when you step on the gas.
        Jerry Fuccillo
        #42179
        Jerry Fuccillo
        • Wayne K.
          • December 1, 1999
          • 1030
          Gary,
          As Jerry has mentioned it will not fully open from heat alone. At full temp the valve is about half open when idling. As rpm increases the exhaust forces it to full open. You can watch it gradually open as you bring rpm's up and partially close as they decrease.
          Wayne
          • Bill E.
            • April 1, 2003
            • 200
            Re: Depends If open, shut, or half open...
            Hello Tom:
            Does the heat riser shaft rotate a full 90 degrees from closed to open? The one on my car only rotates about 45 degress before stopping so the weight isn't pointing straight down to the ground. It sounds like it is hitting something. I wonder if the wrong heat riser was installed.
            Thanks, Bill
            • Rick S.
              • January 1, 2003
              • 1203
              Is there a preventive maintainence recommendation to prevent the heat riser from freezing up?
              Rick
                GM "Heat Riser Valve Lubricant" - made specifically for this application.
                • Rick S.
                  • January 1, 2003
                  • 1203
                  John,
                  Still available at any GM dealer?
                    Yup!
                    • Stephen B.
                      • December 1, 1984
                      • 98
                      this is the best penetrating fluid going even beats pb blaster in my book not just for the heat riser GREAT STUFF my 2 cents Steve
