68 Radio Speaker question - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Does anyone have any suggestions for any replacements for the kick panel speakers in a 68 coupe that will fit behind the stock kick panel grilles? I just purchased two new GM speakers (4 x 10) and they sound terrible.
    Thanks for any suggestions
    Kurt # 26406
  • Kurt B.
    • July 31, 1996
    • 971
    Re: 68 Radio Speaker question
    Am I the only NCRS member who listens to a radio in a Corvette or does everyone else just put up with the junk GM speakers? I paid $40.00 each for these factory correct original speakers and they don't sound worth it.
    Kurt
      • 43221
      Kurt-----
      I think that the problem is that there exists no real solution for this problem. There are many factors involved. First, the factory speakers were/are rated at 10 ohms impedence. The factory original radio requires this impedence. Except for reproductions speakers, you won't find ANY other speakers with this rating, let alone high quality replacements.
      You can usually get by with 8 ohm speakers without too much sound degradation or risk to the integrity of the radio. A 4 ohm speaker will sound terrible, though, and will result in fairly rapid failure of the radio.
      Most of the 8 ohm speakers that you could find will have too large of a magnet to fit in the openings in the pilar posts. Even at that, you very likely won't be able to find anything larger than a 4 inch speaker that would otherwise come close to fitting in the opening.
      Beyond all the above, the original factory radio just doesn't have the technology to produce sound that will sound right to our ears which have become accustomed to sound produced by FAR more modern units.
      • Kurt B.
        • July 31, 1996
        • 971
        Thank you ,Joe *NM*
        • Erik S.
          • January 1, 2005
          • 407
          Re: Thank you ,Joe
          Hi Kurt - I do not know what kind of 68 you have but in my L71 I simply cannot hear the darn radio, regardless what set of speakers i use. So never use the radio myself. Like the sound of the engine better than all the crap on modern radio ;-)
          Erik
          • Kurt B.
            • July 31, 1996
            • 971
            Re: Thank you ,Joe
            Erik,
            My 68 has the L79 motor but you are right about the car being more music to my ears than half the junk on the radio. Once in a while I like to listen to some of the Oldies stations while cruising. Of course, it has been 10 years since I've driven this thing so I may spend most of the time listening to the motor.
            Kurt
              • 11644
              Re: Thank you ,Joe
              Kurt,
              The "best" and usually cheapest option is to have the original speakers re-coned. If you don't have your originals, they are not tough to find as cores.
              Patrick
              • Kurt B.
                • July 31, 1996
                • 971
                Re: Thank you ,Joe
                Patrick,
                Two of the speakers are new and they distort very easily with mid volume level.
                The third has torn paper so I know why that would sound lousy. The thing is with the t-tops off and the noise level of the engine at speed, you need a little volume to be able to even hear them so it is not like I am trying to rock the surrounding towns. Also their location down in the kick panel puts them close to the engine noise so again that requires some decent volume to be able to hear them.
                Have you a source for this reconing thing you speak of?
                Kurt
                  Re: Thank you ,Joe
                  Kurt -
                  Try Jackson Speaker Service in Jackson, Michigan, (517) 789-6400; they've done several for me over the years, and they worked great.
                  • Kurt B.
                    • July 31, 1996
                    • 971
                    Thanks John *NM*
                    • Terry F.
                      • September 30, 1992
                      • 2061
                      Re: Thanks John
                      Kurt,
                      I have heard that even NOS speakers will deteriorate over time for whatever reason. Reconing is supposed to improve the sound. Terry
