brake drums - NCRS Discussion Boards
brake drums
  • Mike Watson
    brake drums
    I need to ID these brake drums, where is a listing on the web or do you have it??
    3752623 and 3828686
    Please email lexopolis@cox.net
    • 43221
    Re: brake drums
    Mike-----
    The 3752623 are applicable to many 51-62 Chevrolet passneger car applications as well as 53-62 Corvette. They are used front and rear for non-metallic and non-HD brake applications.
    The 3828686 are applicable to 63-65 passenger and Corvette REAR application. If this is a part number from a BOX, then it's applicable to non-metallic, non heavy duty applications. If it's the casting number from the drum, then the drums may be either for standard or metallic brake applications.
      • 15677
      Re: brake drums
      The casting number for the 686 finished drum should be 3828688.
      Can you verify?
