master cylinder - NCRS Discussion Boards
master cylinder
  • don 42616
    master cylinder
    The correct M/C was installed on my power brake 67. The brake is somewhat spongy, But the wheels will lock. The M/C was bench bled. Is some fade in the ballpark? Thank, Don
    Re: master cylinder
    Don -
    If the pedal is "spongy", there's still some air in the system - bleed it again.
    • Kurt B.
      • July 31, 1996
      • 971
      Re: master cylinder
      Had the same problem with my 68 a few months ago and it turned out to be air even though I thought I had bled it all out. I let it sit overnight and bled again the next day and a little more air came out and everything was perfect thereafter.
      Kurt
