Clock - Correct Speed Adjustment Face? - NCRS Discussion Boards
  • Mike B.
    • November 1, 2004
    • 389
    On '58 - '62 electro-mechanical clocks, which way should the speed adjustment dial read? Looking from left to right I believe that it should be F-S as is on my '61. But a friend has three old clocks from late 50's era Chevys that look exactly the same but the speed adjustment goes from S-F. Which is correct for the Corvette, and can anyone explain why they are different?
  • Terry D.
    • May 31, 1987
    • 2691
    Re: Clock - Correct Speed Adjustment Face?
    Mike
    You are correct, the "f" is on the left side or the 9 o"clock side. Your friend has clocks from 55-56 Chevrolets.
    • Donald L.
      • September 30, 1998
      • 461
      Mike,
      Your configuration is correct. The early 50s passenger car clocks were slow-fast configuration and were made by New Haven. The later clocks with the fast-slow configuration was made by Westclocks.
