67 fuse problem - NCRS Discussion Boards
67 fuse problem
+ More Options
Posts
  • frank talatzko
    67 fuse problem
    Hey all. Anybody have any ideas why the 4 amp fuse on the panel, for all dash lights, pops every time I pull the headlight switch on ? Its drivin me nuts ! Everything else works fine. 67 convert. Thanks guys
  • Donald O.
    • May 31, 1990
    • 1591
    Re: 67 fuse problem
    You have a short somewhere in that circuit. Now all you have to do is figure out where the short is. Look at all of the gray wires that connect to the dash lights and are fed through the headlight switch. Check you full color wiring diagram.
    Don
